Sign in to follow this
bernie
anyone explain why
Disconnect rear prop, engage diff lock try to drive on front prop to move defender round yard, it tries to move but wont, as though there is a brick under wheel, Tap handbrake housing with fist, vehicle will move round yard, can anyone explain?
Share this post
Link to post
May have cause a restriction after the removal and have no resistance pressure have the original prop attached :unsure: . Also may have not noticed the hand brake had a sticking problem :blink: before when the action from the prop countered the retraction :huh: . Or maybe you had left a brick before :rolleyes:;) when you removed the prop as a safety precaution and forgot to remove the brick ;):D:ph34r::rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: .
Share this post
Link to post
Brake drum not clamped square against the drive flange with prop removed, and binding/jamming on shoes. Missing or loose countersunk screws perhaps?
Share this post
Link to post
