will a 300tdi viscous unit fit on a 200tdi pulley and fan?
Maverik
Hello, just noticed my viscous unit has given up the ghost, firstly can I fit a 300tdi viscous unit into a 200tdi fan then is the thread the same so it fits onto a 200tdi waterpump pulley? - there seems to be more OEM 300tdi units out there over 200tdi ones... anyone got any reccomended brands?
Cheers
Mav
Are the 300TDi ones RH thread, I can't remember :blink: I seem to rememeber that my serpentine V8 is RH but not the TDi.
If it's the same spanner then is it likely to be the same thread?
my LR RAVE info says 300Tdi viscous unit is also LH thread.
Been out and checked in the meantime, our TDi has an electric now anyway.
As far as I can tell it's the same thread as a pre-serpentine V8 and uses the same spanner, the RH thread visocus uses a smaller spanner IIRC (I bought a double ended one and it fits EVERYTHING from the LSE down to my 1298cc Escort).
  • 7 years later...
I can understand why you think it, but it is a misconception that more blades = more air moved for a fan. More blades can however make a fan quieter. Given the clatter of the Tdi engines I can't say I've ever heard any difference between the two.
