Door tops
bobzilla7
evening,
not to sure that best and cheapest go together, but paddocks supply glazed door tops for around £50 each, as do craddocks, i dont think there will be to much differance in price, but a google search may dig up something.
cheers...
when you get them, remove the window lock catch in the frame and pour in loads of waxoil, tilt the frame so that it runs out at both ends and tilt it sideways so that it coats the side of the bottom channel as well. OR buy the all aluminium ones at twice the price! :unsure:
had problem's with Rocky Mountain doortops not being the right shape (they don't follow the windscreen frame), dunno if this is the same with others but may be worth getting unglazed, bend as required and then glaze
I've reglazed in the past on a different vehicle and never had great results.
Who sells ali ones? That makes sense, even at twice the price!
