Jiminy Cricket Posted May 4, 2011 Share Posted May 4, 2011 After finally replacing my rad, its been gone for a year or so! Water now seems to be emitting from around the water pump pully.......time to change the pump aswell or can the seal, gasket be replaced? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 5, 2011 Share Posted May 5, 2011 If water is coming out from behind the pulley and not the gasket face, then new water pump I'm afraid. Les. Quote Link to comment Share on other sites More sharing options...
Jiminy Cricket Posted May 5, 2011 Author Share Posted May 5, 2011 Great! Thanks for the advice.......new pump it is then. Cheers. Quote Link to comment Share on other sites More sharing options...
sgnas Posted May 5, 2011 Share Posted May 5, 2011 If it is a 300tdi, make sure you get an Airtex pump. However easy it is to replace you really do not want to do it twice Quote Link to comment Share on other sites More sharing options...
Jiminy Cricket Posted May 5, 2011 Author Share Posted May 5, 2011 Too late........ :-( let's hope it lasts! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 5, 2011 Share Posted May 5, 2011 Too late........ :-( let's hope it lasts! Please tell me it didn't come in a blue box :o Quote Link to comment Share on other sites More sharing options...
Jiminy Cricket Posted May 7, 2011 Author Share Posted May 7, 2011 Thankfully it came in a green one - like a beer mat! Any hints on how to remoe a REALLY stubborn bolt on the PAS pump pully- cant sort this leak till that blighter is off! Having to add water every day at mo.....dependant on use, its only leeking under pressure. Cheers for the help guys. Please tell me it didn't come in a blue box :o Quote Link to comment Share on other sites More sharing options...
sgnas Posted May 7, 2011 Share Posted May 7, 2011 Any hints on how to remoe a REALLY stubborn bolt on the PAS pump pully- Put the others back in. Spanner/socket on one you can remove and use it as a lever to stop the pulley rotating while you have a go on the stubborn one. Quote Link to comment Share on other sites More sharing options...
