tuko Posted May 6, 2011 Share Posted May 6, 2011 I've been searching for the better part of a half hour for a definitive answer that I swear I seen one time before (possibly written by Jim) without luck. A friend called tonight and needs help with wiring his 300Tdi injector pump, the stop solenoid has the silly black box over it and 3 wires coming from that. (He's transplanting a 300Tdi in an early RRC) The closes thread that I can find that approaches my search is this: http://forums.lr4x4.com/index.php?showtopic=33130&st=0&p=321479&hl=+stop%20+solenoid%20+wires&fromsearch=1entry321479 BUT there is no real answer there. Wasn't this discussed a few months ago and an answer was given? Would really appreciate being steered in the right direction guys. Thanks, Todd. Quote Link to comment Share on other sites More sharing options...
western Posted May 6, 2011 Share Posted May 6, 2011 I guessing the engine is from a 300Tdi Discovery ? if so, the page below might help. if it's from a Defender 300Tdi just remove the black box & the solenoid is under it,as mentioned in the last reply in the link you posted Quote Link to comment Share on other sites More sharing options...
tuko Posted May 6, 2011 Author Share Posted May 6, 2011 Thanks for the reply Ralph. The engine that he's transplanting is from a 1998 Discovery. If he does remove the black box, what will happen? I mean, will the wires follow with the black box and simply leaves the stop solenoid exposed so that he can wire an ignition lead to it? Sorry for the additional questions but I don't want to tell him to do something if I'm not clear with it in the first place. I was luck with my transplant, I used a '97 Defender motor with no electronics on the injector pump. Thanks, Todd. Quote Link to comment Share on other sites More sharing options...
western Posted May 6, 2011 Share Posted May 6, 2011 black box removed will just expose the stop soleniod, just the same as a Defender 200 or 300tdi, then connect the energising wire to the stud/nut on the soleniod again as per a standard defender 200 or 300tdi. Quote Link to comment Share on other sites More sharing options...
