jericho Posted May 7, 2011 Share Posted May 7, 2011 Fitting a brantz speedo cable sensor. I've read the instructions. How can I remove the inner cable to slide it trough the sensor when each end has moulded or crimped fitting on it? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 7, 2011 Share Posted May 7, 2011 When I did mine many moons ago.. I just removed the inner square section by pulling it out 2 piece speedo cable, then cut the outer sleeve where you wanted the sensor to fit, which then clamps into either end of the sensor, then pass the square section all the way through. that was it ! it was a few years ago and the sensor head might have changed Quote Link to comment Share on other sites More sharing options...
jericho Posted May 7, 2011 Author Share Posted May 7, 2011 I don't think the sensors have changed. On the one piece cable I can't see any way to pull the inner cable out,short of cutting the end off. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted May 7, 2011 Share Posted May 7, 2011 i have an 85 lr110 which has a two piece cable,perhaps one of those would suit. Quote Link to comment Share on other sites More sharing options...
