Sticky Handbreak Knob
Jamest535
Had this problem on my wifes Disco. Cured it by pulling the knob off (oo er missus!), its just a push fit, gave it a rub with some fine sand paper, then put three suitably sized washers on the metal rod before sticking it back on. Works a treat. The more washers you use, the further it sticks out.
Cheers
Log
Can be caused by somebody taking the centre console out and inadvertently bending the operating rod running through the middle of the lever while doing this. You need to straighten the rod but it can be diffcult to get right!
