Abdur 0 Posted December 19, 2017 Share Posted December 19, 2017 41 minutes ago, Bowie69 said: Yes, second option makes most sense for you , parts are probably cheaper where you are as well. Thanks. By the way how much of the output shaft needs to be cut? Quote Link to post Share on other sites
Bowie69 1,449 Posted December 19, 2017 Share Posted December 19, 2017 Measure to compare to the surf box Quote Link to post Share on other sites
miggit 10 Posted December 19, 2017 Share Posted December 19, 2017 If you're looking at a centre diff rear axle, you might want to think about a Landcruiser 80 series.... they have an electronic diff lock! Disc brakes with an internal drum handbrake. Some of the Y60 Patrols had LSD's, but in my experience the Toyota axle is better in the sticky stuff! Quote Link to post Share on other sites
Bowie69 1,449 Posted December 20, 2017 Share Posted December 20, 2017 LC80 is offset like a LR... Quote Link to post Share on other sites
RedLineMike 129 Posted December 20, 2017 Share Posted December 20, 2017 y61 patrol axle is ideal, plus given abdur's location, they will be a LSD axle which is more robust than the vacumn locker we got in the uk which breaks Quote Link to post Share on other sites
Bowie69 1,449 Posted December 20, 2017 Share Posted December 20, 2017 Ideal solution then Quote Link to post Share on other sites
miggit 10 Posted December 20, 2017 Share Posted December 20, 2017 So if the 80 Series is offset (very slightly that's why I'd forgotten), why not use the 80 series box, complete? they have a locking centre diff... the only thing they'd be lacking is the transmission brake... but I'm sure you could cobble up an X engineering type disc! Oh and they came in either 5 speed manual or 4 speed O/D auto with lockup at around 40 Mph.... none of this silly 90% lockup at 30-50, which eats torque converters when towing... the LC was either on or off.. way better! Quote Link to post Share on other sites
Bowie69 1,449 Posted January 9, 2018 Share Posted January 9, 2018 @Abdur, I found the thread that I cribbed the surf transfer case swap from, see pics here: http://www.lextreme.com/forums/index.php?threads/hilux-surf-ln130-1uz-fe.11361/ Quote Link to post Share on other sites
