JemFI Posted May 31, 2011 Share Posted May 31, 2011 Hi everyone. After some advice. Looking at buying a Td5 Discovery, ex police with 150,000 miles on the clock. It has the 3 aimgos lit up and the SRS light on. Is it a vehicle to look at or one to stay away from? Quote Link to comment Share on other sites More sharing options...
MartinK Posted June 1, 2011 Share Posted June 1, 2011 I wouldn't worry about the mileage, if it's had a really good service history, 150,000 miles is OK on the engine and drive train. What age is it? 2002 onwards (i.e. the late square-headlight models and the newer "facelift" models) had a lot of improvements, such as the replacement of plastic locating dowels in the head with better metal ones. Have a good look for corrosion - some early D2's are now reporting chassis rust (to the point where welding is needed). Sounds like you know most of the rest: * 3 Amigos - may be just a wheel bearing or an ABS sensor * Wheel bearings are expensive. Guide to replace here: http://www.discovery2.co.uk/fronthub.html - but once done it should be OK for at least 90k miles. * If it's SRS/Air Suspension and ACE, consider binning ACE and getting Coil Springs (when they both become problematic...which the WILL). * If it has a sunroof, it WILL leak * SRS fault is often traced to poor connections, have a google search... If there was a way of getting the car onto a diagnostic, then you would probably pinpoint the 3 Amigos and SRS issues in 5 mins. Solid car, love mine, owned from new now on 181000 miles. Quote Link to comment Share on other sites More sharing options...
