Rich_P Posted June 11, 2011 Share Posted June 11, 2011 I understand the obvious differences between single point and multi point LPG systems, and I am aware that there are those which make use of exhaust sensors I think and those which do not? Anyway, the important question is, can a single point system be upgraded to multi point without having to replace the vaporiser and tank(s) etc? Is the difference only after the vaporiser? Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted June 11, 2011 Share Posted June 11, 2011 I understand the obvious differences between single point and multi point LPG systems, and I am aware that there are those which make use of exhaust sensors I think and those which do not? Anyway, the important question is, can a single point system be upgraded to multi point without having to replace the vaporiser and tank(s) etc? Is the difference only after the vaporiser? In simple terms... No.. You can use the tank and pipe work to the single point vaporiser but that's it. The rest will need to be replaced. HTH Jeff Quote Link to comment Share on other sites More sharing options...
Rich_P Posted June 11, 2011 Author Share Posted June 11, 2011 So the tank, pipes to the vap and the vap itself can remain the same? That's what I was hoping to hear. Thanks. Quote Link to comment Share on other sites More sharing options...
webbersdad Posted June 11, 2011 Share Posted June 11, 2011 So the tank, pipes to the vap and the vap itself can remain the same? That's what I was hoping to hear. Thanks. No. You can use the tank, and tube from the tank to the vaporiser, thats it. webbersdad. Quote Link to comment Share on other sites More sharing options...
