TD5 No throttle response
Phantom
Got a D2 Td5, when you start her up she's 'lumpy'and won't rev in any way what ever you do with the throttle ( Hot and cold ). After a wait, 20 seconds, sometimes a minute you can hear the engine note change and she rev's and drives fine.
Today I popped a fuel pump in her, new fuel pump relay, new filter, new MAF sensor( also tried the old one unplugged ) and pulled out the ECU and injection harness ( no oil in either ). Plugged into Hawkeye and no faults.
You can leave her for an hour or start her immeadiatly after stopping the engine and every time she won't rev, until the engine note changes and then all OK
What to do next?
Thanks in advance
Lee
What to do next?
Thanks in advance
Lee
Hi lee when this problem appears have you noticed if the glow plug light comes on?
phil
  • 9 years later...
If diagnostics indicate a problem with the throttle pedal, make sure to check the wiring before replacing the pedal. I've had a customer with a TD5 that would go into limp mode seemingly at random, especially in wet weather. Turned out the wiring loom was chafed and when moisture got in that would interfere with the signal from the pedal potentiometer. Cheap fix with shrinkwrap and tape.
Filip
The pedal has (depending on age) either two or three 'driver demand' potentiometers. The ECU checks these against each other (largely a safety net that means you don't get a failure which gives you 100% throttle... an electronic spring on the injector pump if you like) so if there is a mismatch then it won't rev. You need a diagnostic to get a live readout of the pedal track outputs and check for driver demand faults. It is most likely to be the pedal but not always. Make sure you get the right sort of pedal (part number off the pedal assy) if you are ordering one.
