chrisstevenson Posted August 31, 2005 Share Posted August 31, 2005 Hi, Just about to set off on a 4000 mile trip round Europe and all of a sudden tonight noticed a slight rumble from the rear prop on the overrun, I think I'm gonna carry a spare prop for this trip. However there appear to be 2 props fitted to the Disco, one is nice and cheap at £65 + VAT (FRC8387) and these were fitted to early and VA onwards vehicles, but for my MA chassis Paddocks website lists FTC3705 at over £125 + VAT!!!! Can I fit the FRC8387 instead or are the diff and transfer case flanges different on this vehicle? HELP!!! Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Share Posted August 31, 2005 pm me your registration number and is it a 300TDI/V8 of MPI Quote Link to comment Share on other sites More sharing options...
Budgie Posted August 31, 2005 Share Posted August 31, 2005 Chris, FTC8387 have a U/J at each end (200 TDI & V8) and FTC3705 (300 TDi) have a U/J at the gearbox end and a large rubber doughnut at the diff. If you're in need of FTC3705 then I have a spare up here that needs a new doughnut but is okay apart from that. I could post it too you, just depends on when you're leaving as it'll take until maybe Monday to get South!! Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Share Posted August 31, 2005 microcat shows FTC3705 for your chassis number check to see if you have a UJ at each end or not Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted August 31, 2005 Author Share Posted August 31, 2005 Hi, Thanks for the speedy response! Its got a UJ at one end only, its a 3.9 auto chassis MA14xxxxx, do I have to replace with same or can I fit the cheaper "UJ at each end" type. Will this fit? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Share Posted August 31, 2005 yes you can replace it but you need to change the drive flange on the diff end this has a guide inplace covering the nut on the flange and is a bstid to remove requiring a slide hammer and some heat to clear the loctite. why not just buy a UJ and rubber doughnut and carry them as spares. the rubber one is dead easy to c/o the U/j can be replaced byt any garage or carefull use of a hammer/socket best if you can find a vice. I would change them before leaving and carry the two pieces mentioned above. Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted August 31, 2005 Author Share Posted August 31, 2005 Thanks, I found the UJ part number on Paddocks site but no part number for the rubber donut so dont know if its a replacable item? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Share Posted August 31, 2005 yes it certainly is STC2794 try exeter 4x4 store they'll match any price 01392 445262 ask for Alistair Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted August 31, 2005 Author Share Posted August 31, 2005 ok will do thanks! Is it also known as part number TVF100010? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 1, 2005 Share Posted September 1, 2005 There is a new part number for the coupling kit which is TVF something so probably yes, I can't check at the moment but that is probably right. Just a superceded number AFAIK. I would be inclined to fit the UJ at each end type, this is fitted to some later V8 Disco's I have seen a 1998 model one with a twin UJ rear prop (factory fitted) though my own 1996 model had a doughnut. Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted September 1, 2005 Author Share Posted September 1, 2005 Yes, it looks like they went back to UJs at each end in 1997/98 for the V8. I would love to change to the UJ type but dont have the time to remove the rear diff flange now, might even struggle to buy one today! Thanks. Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted September 1, 2005 Share Posted September 1, 2005 If you're on a tight time limit, shove on a new rubber donut (Rotoflex) coupling for now to get you on your way. You can swap to the traditional UJ at either end type prop, but as Tony has said, the three bolt flange for the rubber donut can be/will be a complete B'stard to remove. Ask me how I know! Sods law dictates if you've a ferry to catch, yours will be a nightmare to change. To save yourself any headaches, change like for like for now. If you do upgrade your prop at a later date, there is a prop flange kit available with all the parts included. If you manage to rob a flange off a 2nd hand diff, remember to fish out the thick spacer that lives tucked away behind the prop-flange. Kev Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted September 1, 2005 Author Share Posted September 1, 2005 Is the rotoflex coupling easy to replace? Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted September 1, 2005 Share Posted September 1, 2005 Changing just the coupling is the easy job. Half and hour with a couple of spanners should cover it. Kev Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted September 1, 2005 Author Share Posted September 1, 2005 What about the UJs? Can these be done at the side of the road???! £35 for the parts V £145 for the prop makes me more inclinded to run it until the UJ is totally FUBAR - but only if its realativly easy to sway both the UJ and the rotoflex... talk about a gamble! Youve convinced me on the rotoflex but I've never done a UJ before. Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted September 1, 2005 Share Posted September 1, 2005 To swap UJ is a trickier job. Easy when you now how-not so easy when you don't. Definitely not one for the side of the road. Essentials are a vice, circlip pliers, big hammer and a grease gun. Conveniently for you, there's a piece of swapping a UJ in the latest Oct issue of LRW. Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted September 1, 2005 Author Share Posted September 1, 2005 Decided to go for both, new prop and the parts to repair mine, if I dont use the prop I can take it back for a refund. Excellent! On another matter (slightly paranoid I know but that what happend when you spend so much time reading about other peoples landrover problems) .... if a front CV joint clicks very slightly on full lock when reversing is this anything to worry about or fairly normal, is it likely to suddenly disintegrate or progressivly get worse? Quote Link to comment Share on other sites More sharing options...
Budgie Posted September 1, 2005 Share Posted September 1, 2005 If the CV is clicking without the difflock engauged then I woud tend to change it, if it's OK without difflock then you should be alright, just change it when you get back. Quote Link to comment Share on other sites More sharing options...
