TobyMellin Posted June 19, 2011 Share Posted June 19, 2011 Hi Guys I've just fitted a second hand Accelerator pedal unit with potentionmeter as my old one had a nackered potentionmeter, but I can't seem to get it to work. Is there something you need to do apart from plugging it in and bolting it to the bulkhead? Cheers Guys Toby Quote Link to comment Share on other sites More sharing options...
stuck Posted June 19, 2011 Share Posted June 19, 2011 Hi Toby, Are you sure that both pots are the same? There are two and three track varieties knocking about... HTH's Mick. Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted June 19, 2011 Author Share Posted June 19, 2011 Oooo....what's the easiest way to tell them apart? It was off a TD5 not too newer than mine. Mines a 99 Td5. Silly fly by wire, my old 2.5td was so much simpler Toby Quote Link to comment Share on other sites More sharing options...
kiwi_110 Posted June 19, 2011 Share Posted June 19, 2011 Microcat says "From (V)XA159807 to (V)1A607224 use SLC100210" and "From (V)1A607225 on use SLC000010PMA" Hope that helps! Ray Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted June 19, 2011 Author Share Posted June 19, 2011 Microcat says "From (V)XA159807 to (V)1A607224 use SLC100210" and "From (V)1A607225 on use SLC000010PMA" Hope that helps! Ray I'll have a look when I get in Cheers Guys Toby Quote Link to comment Share on other sites More sharing options...
