del Posted June 20, 2011 Share Posted June 20, 2011 hi all, got a smokey 200 tdi ,someone mentioned theres an additive you can add to the engine to sort of coat the pistons is it worth it? Quote Link to comment Share on other sites More sharing options...
western Posted June 20, 2011 Share Posted June 20, 2011 try some Millers diesel fuel injector cleaner Quote Link to comment Share on other sites More sharing options...
kiwi_110 Posted June 20, 2011 Share Posted June 20, 2011 What colour is the smoke? Blue = burnt oil = rings, pistons, valve guides etc, an additive "might" reduce this, but a rebuild is inevitable. Black = unburnt diesel = dirty injectors, pump tweaked too high, blocked air filter. Ray. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 20, 2011 Share Posted June 20, 2011 No additive can fix a knackered engine - at best you'll mask the problem. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 22, 2011 Share Posted June 22, 2011 No additive can fix a knackered engine - at best you'll mask the problem. Except AMT Engine Restore - it microscopically rebuilds your engine so that it doesn't have to be worked on. It says so on the £80 tin, and Quentin Wilson endorses it; his word as a second-hand car salesman has to be taken. Like Fridge says, if you have engine wear that is causing oil burning, then you either have to live with it if it's a small amount or rebuild/replace the engine if it's burning a lot. The only oil additives that make much difference are the oil seal rejuvinators which can help soften and swell a tired and hardened seal. Quote Link to comment Share on other sites More sharing options...
