Evomanny Posted June 29, 2011 Share Posted June 29, 2011 My 2004 TD4 now has 2 warning lights that randomly come on during normal town driving. One is the TC light and the other is what i presume is the hill descent light. Any idea what could be causing this? Thanks Quote Link to comment Share on other sites More sharing options...
MJIbex Posted June 29, 2011 Share Posted June 29, 2011 Dodgy brake pedal switch - would be my 1st guess. If an auto are you using both feet? Mark. Quote Link to comment Share on other sites More sharing options...
Litch Posted June 30, 2011 Share Posted June 30, 2011 Really common problem and if you search you will find plenty of information about it. In the case of my wife's vehicle (2006 TD4) it was becasue the brake-light switch was not clicked into position, after reading up on possible causes it took me about 30-seconds to diagnose and less than 10-seconds to fix. Quote Link to comment Share on other sites More sharing options...
Evomanny Posted July 1, 2011 Author Share Posted July 1, 2011 Thanks for that...new switch ordered....nice little job for the weekend Quote Link to comment Share on other sites More sharing options...
Litch Posted July 1, 2011 Share Posted July 1, 2011 Did you check that the switch was in position first or are you just going to risk it that the switch is the fault? I have to admit they are so cheap and easy to replace that it isn't a bad thing because even if it doesn't cure it at least you can be 100% certain you have eliminated it as a possible cause. Quote Link to comment Share on other sites More sharing options...
Evomanny Posted July 4, 2011 Author Share Posted July 4, 2011 I just changed it to be on the safe side, it was located o.k but it did feel as if it waas sticking a bit when i worked it. Fitted new one (£9) and so far so good. Thanks for the help Quote Link to comment Share on other sites More sharing options...
Stacey Posted March 28, 2018 Share Posted March 28, 2018 can anyone send a picture of where the switch is or a link to video so I can fit my new brake switch? Quote Link to comment Share on other sites More sharing options...
