Immobiliser by-pass for an EDC 300TDi
Pete Attryde
 Share
Hi,
Have been hanging around on here for a while, but not posted much as I have not had anything to ask.
However, The immobiliser on my 1996 300TDi Auto with EDC is showing early signs of imminent death, ie not always de-immobilising. I have done the usual and changed the remote batteries and also fitted a new good vehicle battery. But every now and then the car will not start (in fact all I get is the usual dash lights but not the starter turning.) if I wait between 5 and 10 minutes the damn thing starts fine.
So anyway I decided after reading Bogmonsters guide to spider repair (and being an electronics engineer with no fear of soldering) to take the dash apart (was also fitting a new headunit) and repair the little black box. Here arrises the problem, Dash all out, expect to see little black box but nothing there, B****r, Ok consult the RAVE disc I have (North American but close enough) and find that the EDC equipped vehicles don't have the little black box!!!!!.
So as the title says, how do I disable/remove/bypass the immobiliser and alarm from my wagon?
Ideally would like to junk the whole system and install an aftermarket one at a later date.
Anyone help?
Thanks in advance,
Pete.
hi pete, i have a 94 300 tdi without the black box and mine went on the fritz. you need to speak to ian i think his name is at www.remotekey.com.
he was very helpful and sorted my problem out. hope this helps
ade
ade
I'll second the vote for Remotekey - he's helpful and the prices are very reasonable - MUCH cheaper than a main stealer.
 Share
