land_rover_one_ten Posted June 30, 2011 Share Posted June 30, 2011 Hi All I want to replace the Drive Members front and back on my 1988 110 CSW. Can someone check the parts numbers for me? x4 FRC5806 Drive Member x4 FRC3988 Gasket x4 FRC4377 Dust Cap (Leaking oil so might as well replace) x20 FC110107L Drive Member Bolt x20 WL110001L Bolt Spring If I order that lot should I be ok? The one that looks a bit odd is the bolts (FC110107L): http://www.lrseries.com/shop/product/listing/13761/AFU1181-FLANGED-HEAD-BOLT-M10-x-50.html Looking at the ones currently on my 110 they do not have a flanged head. Does that matter? Also I have heard there is a 'thick' gasket FRC3988? If I go genuine will I be ok? http://www.lrseries.com/shop/product/listing/6408/FRC3988-AXLE-DRIVE-MEMBER-GASKET.html Cheers Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 30, 2011 Share Posted June 30, 2011 I wouldn't change the bolts unless they were knackered. New spring washers is a good idea though, and give them a dab of threadlock as they have a habit of coming undone! Genuine gaskets all the way, some aftermarket ones are wafer-thin and therefore useless Quote Link to comment Share on other sites More sharing options...
western Posted June 30, 2011 Share Posted June 30, 2011 retain the existing bolts fit with new spring washers & the thicker gasket. you can check the part numbers here on page 420 Front & page 427 Rear Quote Link to comment Share on other sites More sharing options...
Escape Posted July 4, 2011 Share Posted July 4, 2011 Or use sealant instead of the gaskets, we always do. Less sensitive and so less chance of leaks. Just a bit more work to clean up if you have to take the members of again. Quote Link to comment Share on other sites More sharing options...
land_rover_one_ten Posted July 4, 2011 Author Share Posted July 4, 2011 Thanks guys. I am having problems getting hold of the FRC5806 Drive Member. I was after the OEM version made by AllMakes usually listed as FRC5806G. The trouble is everyones website claim they have it but actually they order from AllMakes who then tell them they will have no stock until 2012! Has anyone fitted another brand of driver member that has lasted well? What about these? http://mattsavage.com/acatalog/Drive_Flanges.html As I understand it they might wear my half shafts faster and will no longer be the weakest link in the drive train. Cheers Quote Link to comment Share on other sites More sharing options...
