chris200100 Posted June 30, 2011 Share Posted June 30, 2011 Hi all, I've been racking my brains out why my heater isnt working right, basically it doesn't blow any hot air at all, there is a very slight difference between cold and hot but very slight. I've checked the pipes they are both getting hot, the flaps inside are working as they should, the cable are all set correctly, the matrix it self looks fine no holes, I've flushed the system as to landrovers method still no joy. Is there anything else that I should check Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 30, 2011 Share Posted June 30, 2011 Have you checked the thermostat? How long does the temperature gauge take to get to running temp? My heater was pathetic till I replaced the thermostat. Quote Link to comment Share on other sites More sharing options...
chris200100 Posted June 30, 2011 Author Share Posted June 30, 2011 No I haven't checked the thermostat will do tomorrow, as for it warming up it dosen't take long and the gauge go halfway and stays there. Quote Link to comment Share on other sites More sharing options...
western Posted June 30, 2011 Share Posted June 30, 2011 just shove a new 88degree genuine LR stat in. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 30, 2011 Share Posted June 30, 2011 No I haven't checked the thermostat will do tomorrow, as for it warming up it dosen't take long and the gauge go halfway and stays there. Mine was taking a long time to warm up as thermostat was stuck open and that was stopping the heater doing much unless you were going up a steep hill. If yours is warming up quickly then your thermostat is probably ok, but if you have checked everything else you can think of then it won't do any harm to have a look. Quote Link to comment Share on other sites More sharing options...
Nigel May Posted June 30, 2011 Share Posted June 30, 2011 If you've checked everything else, it sounds like an airlock in the heater matrix to me. Quote Link to comment Share on other sites More sharing options...
dan9090 Posted June 30, 2011 Share Posted June 30, 2011 taking it back to basics, is the blower motor working? (ie: can you feel the difference in airflow when you switch on the blower?) had to replace mine recently and prior to that you could barely feel the heat on account of the very little air passing through. Quote Link to comment Share on other sites More sharing options...
chris200100 Posted June 30, 2011 Author Share Posted June 30, 2011 Blower is working fine plenty of air coming from the heater just no heat, I will check the thermostat see what's going on with that. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted June 30, 2011 Share Posted June 30, 2011 before you jump and think thermostat... its worth checking that the flap inside the heater box is at least moving.... it might just be that the lever has become detached form the operating arm... mine did! Quote Link to comment Share on other sites More sharing options...
chris200100 Posted July 1, 2011 Author Share Posted July 1, 2011 before you jump and think thermostat... its worth checking that the flap inside the heater box is at least moving.... it might just be that the lever has become detached form the operating arm... mine did! All ready checked them both flaps are working as they should. Quote Link to comment Share on other sites More sharing options...
Ian Barrett Posted July 1, 2011 Share Posted July 1, 2011 If both pipes are getting hot, and the flaps inside are working OK then surely either the matrix is full of kak and water is only trickling through or there is an air lock in it. Isn't there a trick to getting the air out by jacking up the front end or something? Quote Link to comment Share on other sites More sharing options...
chris200100 Posted July 1, 2011 Author Share Posted July 1, 2011 Well I've checked the thermostat and that's working fine I'm really stumped now. I think the next thing to try is pull the heater out again and take the matrix out and connect the pipes up and see if it's getting hot. Other than that I'm lost if it is an air lock in the heater how on earth do you get rid of it? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 1, 2011 Share Posted July 1, 2011 Slacken the jubilee clip on the return pipe at the heater end to let air out of the matrix. It worked for me Mo Quote Link to comment Share on other sites More sharing options...
