TJ101 Posted July 21, 2006 Share Posted July 21, 2006 To save a search, does anyone from the top of their head, remember the wire colour code, on a defender main/dip switch feed ?? Thanks all Quote Link to comment Share on other sites More sharing options...
simonb Posted July 21, 2006 Share Posted July 21, 2006 Think(....) its either blue/red or blue/black. Other side of the switch IIRC is blue/pink or blue/white. Basically any blue thickish wire with a tracer is main/dip lighting. This is common for all Rover vehicles. Someone will either prove me right or wrong... Quote Link to comment Share on other sites More sharing options...
mpb Posted July 21, 2006 Share Posted July 21, 2006 To save a search, does anyone from the top of their head, remember the wire colour code, on a defender main/dip switch feed ??Thanks all From the Defender Wiring Diagram it's a Blue/Red wire that goes from the dim/dip switch to the dim/dip relay. Hope that helps. Quote Link to comment Share on other sites More sharing options...
OilIT Posted July 22, 2006 Share Posted July 22, 2006 Think(....) its either blue/red or blue/black. Other side of the switch IIRC is blue/pink or blue/white. Basically any blue thickish wire with a tracer is main/dip lighting. This is common for all Rover vehicles. Someone will either prove me right or wrong... When I did my spots the Haynes showed me a Blue with white tracer. If your wiring in spots then beware I found one in the left hand front wing, but when I used it it had strange results, so ended up taking the feed from the wire going into the switch on the column - worked fine (if your not doing this - or know why it didnt work for me then good luck - but blue & white it was and they work when I put on main beam - goes off when I dont!!) Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 22, 2006 Author Share Posted July 22, 2006 Thanks Guys,, Blue/White it was, Having a wiring tidy up, and sorting a dicky winch switch, so while being there, sorting out the lamp pod loom !! Thanks again Quote Link to comment Share on other sites More sharing options...
