western Posted July 23, 2006 Share Posted July 23, 2006 Would someone please look at their 110 [preferable 1988 to 1990 models] & tell me what colour wires connect to the double connector [black/white tracer,1 x male & 1 x female bullet type fittings] that feeds the brake pressure differentail warning actuator [PDWA] at the upper end adajacent to the brake servo/clutch master cylinder, I'm not sure if I've reconnected mine correctly [reason in the process of fitting a new main harness after a bit of a meltdown] Cheers for your efforts in advance Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 24, 2006 Share Posted July 24, 2006 Would someone please look at their 110 [preferable 1988 to 1990 models] & tell me what colour wires connect to the double connector [black/white tracer,1 x male & 1 x female bullet type fittings] that feeds the brake pressure differentail warning actuator [PDWA] at the upper end adajacent to the brake servo/clutch master cylinder, I'm not sure if I've reconnected mine correctly [reason in the process of fitting a new main harness after a bit of a meltdown]Cheers for your efforts in advance I've just had a quick look at mine. I'm retty sure it has a PDWA but I can't find it. I'll look in the parts cat and try and see where it is exactly. I assume the connector you seek is on the bulkhead? Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 24, 2006 Share Posted July 24, 2006 I've just compaared with the parts cat and I don't have one fitted. Now, I wonder what the brake light coming on when the key is in the start position means, if you don't have the PDWA fitted There - I've been no help what so ever -sorry! Quote Link to comment Share on other sites More sharing options...
simonb Posted July 24, 2006 Share Posted July 24, 2006 On a 90 300tdi, (without pdwa) one is parking brake, the P symbol, although there is also one marked "parking brake" which in typical LR fashion isn't used, and the other is the I symbol which is fluid loss. On mine this also illuminates when the handbrake is on, as well, as a bulb test. If it comes on at other times - potential brown trouser moment Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 I've just had a quick look at mine. I'm retty sure it has a PDWA but I can't find it. I'll look in the parts cat and try and see where it is exactly.I assume the connector you seek is on the bulkhead? it's bolted to the engine side of bulkhead below the clutch pedal housing, the pdwa connector comes from the bottom & up to the bulkhead plugs, Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 From what I can make out the feeds into the connector are black with white tracer too Ralph. Pics to follow. Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 Great thanks Steve Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 Your a Star Thank you very much, the picture confirms I've connected it properly Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 My pleasure Quote Link to comment Share on other sites More sharing options...
