Countax Posted July 24, 2006 Share Posted July 24, 2006 My D90 gets long periods of storage between use and consequently the rear brake shoes get time to rust at the circular pivot points at the bottom of the shoes. Is it ok to put a very small amount of copper grease on the circular pivot point to keep the moisture and rust at bay? Nigel Quote Link to comment Share on other sites More sharing options...
Diff Posted July 24, 2006 Share Posted July 24, 2006 My D90 gets long periods of storage between use and consequently the rear brake shoes get time to rust at the circular pivot points at the bottom of the shoes.Is it ok to put a very small amount of copper grease on the circular pivot point to keep the moisture and rust at bay? Nigel Yes, you can use copper anti sieze (sparingly)on any of the metal to metal contact points. I always give the centre hole of the drum a quick rub round with emery cloth and a thin smear of copper slip to make it easier to remove the drum next time too. Regards, Diff Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Share Posted July 24, 2006 Yep, use it sparingly & you'll be OK. Quote Link to comment Share on other sites More sharing options...
Countax Posted July 24, 2006 Author Share Posted July 24, 2006 Yep, use it sparingly & you'll be OK. Thanks guys, will take your advice and use it sparingly. Nigel Quote Link to comment Share on other sites More sharing options...
