western Posted July 24, 2006 Share Posted July 24, 2006 Please all I need some help with this, just need to know which wire fits to which terminal [originally & '89 2.5TD now with a 200Tdi.I should have made a maps of where all the different wires connect to, but I didn't.Ignition switch connections, diagran looking at the back of the switch, terminals numbered for easy ref only, I know 2 is the main feed from the battery & 1 is not used [ex.2.5TD glowplug/main feed]many thanks in advance Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 Ralph, I've just responded to your other spaghetti query in the Defender forum Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 Ralph, I've just responded to your other spaghetti query in the Defender forum Thanks very much, I've replied, the picture you added confirms my connections, You can have a go at this spaghetti puzzle now if you want too Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 I've only got the V8 130, TD5 90 CSW & TD4 Freebie here and doubt the looms are the same Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 (edited) I've only got the V8 130, TD5 90 CSW & TD4 Freebie here and doubt the looms are the same The V8 loom maybe to a certain extent, but the ignition wiring would be diffent for a petrol & the others will be way off , many thanks for helping anyway Edited July 24, 2006 by western Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 24, 2006 Share Posted July 24, 2006 Aye, I was kidding about the TD5 & Freebie but did think about having a shufty at t'other one. I'll do so if nobody else steps into the fray. Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 Quote Link to comment Share on other sites More sharing options...
Edd Posted July 24, 2006 Share Posted July 24, 2006 Ive gto a pic of teh ignition on my 2.25 diesle 110 which i can dig out for you in the morning if that helps. (would do it now but am stuck at work) Edd Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 Ive gto a pic of teh ignition on my 2.25 diesle 110 which i can dig out for you in the morning if that helps. (would do it now but am stuck at work)Edd Thanks Edd, that would be good. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 24, 2006 Share Posted July 24, 2006 I've got some wire if you need any. I'll get me coat Les. Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2006 Author Share Posted July 24, 2006 I've got some wire if you need any.I'll get me coat Les. trust you Quote Link to comment Share on other sites More sharing options...
Guest mr_wuffles Posted July 25, 2006 Share Posted July 25, 2006 Ralph i think the answer is in the 200 Tdi retro-fit manual. Quote Link to comment Share on other sites More sharing options...
western Posted July 25, 2006 Author Share Posted July 25, 2006 (edited) Ralph i think the answer is in the 200 Tdi retro-fit manual. Had a look at mine & on your site, it only tells where to connect the new glowplug time relay loom cables to, To all, Cheers for comments/help, I've got it sorted now & engine starts/runs OK, just the instruments to double check/test, front lights to refit/reconnect & a few other bits to do. for info & future reference numbers relate to my drawing above ----- No connection[at terminal 1, nearest steering wheel] Brown [batt 12v feed to terminal 2 @ 12o'clock position] White [to terminal 3] White/Red [to terminal 4] White/black [to terminal 5] White/orange [not connected as it becomes live -- for accessory/air conditioning-- when ignition switch to position 2 glowplug/pre spring loaded start section of switch] Note -- above info only for a ex-2.5TD engined vehicle that's been converted to a 200Tdi engine. But might be useful for 2.5n/a to 200Tdi if you fit the glowplug timer relay & associated wiring. Edited July 25, 2006 by western Quote Link to comment Share on other sites More sharing options...
LNDRVR2 Posted June 21, 2010 Share Posted June 21, 2010 I know that this is a rather old thread but I am looking for some help in identifying the terminals on the bottom side of the timer relay. I was not lucky enough to get the harness and relay plug so I will go about making up one myself. The problem I have is that I am unable to identify the pins on the bottom of the relay as they appear to be sealed with silcon and I am unable to see anything under it. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
western Posted June 21, 2010 Author Share Posted June 21, 2010 I know that this is a rather old thread but I am looking for some help in identifying the terminals on the bottom side of the timer relay. I was not lucky enough to get the harness and relay plug so I will go about making up one myself. The problem I have is that I am unable to identify the pins on the bottom of the relay as they appear to be sealed with silcon and I am unable to see anything under it. Any help would be greatly appreciated. the attached .pdf file & this photo should help you ident the terminals. Timer relay connections.pdf Quote Link to comment Share on other sites More sharing options...
GBMUD Posted June 23, 2010 Share Posted June 23, 2010 I thought I saw banter there. ^^^^ Mods too! Chris Quote Link to comment Share on other sites More sharing options...
headhunter Posted June 23, 2010 Share Posted June 23, 2010 Those were the days! John Quote Link to comment Share on other sites More sharing options...
