stuck Posted July 22, 2011 Share Posted July 22, 2011 Never taken a LR gearbox out before, Is the bracket shown in the manual necessary or is it easy enough to balance the box on a decent trolley Jack? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 22, 2011 Share Posted July 22, 2011 If you're careful, yes that's possible. Or build a wooden jig to hold it steady on the jack. Personally I'd lower it from a frame inside the vehicle. Either an engine hoist in through the door, or a bit of box-section over the seat bases (for transfer box) or over the transmission tunnel/footwells (for main gearbox) with some rachet straps that you can let down gradually. Quote Link to comment Share on other sites More sharing options...
wermy Posted July 22, 2011 Share Posted July 22, 2011 My vote is for an engine crane in through the door Just a rope looped front and back of the main / transfer box and knock the crossmember out before lowering. You have a lot more control over the whole process and you can twist it all so that it line up. Quote Link to comment Share on other sites More sharing options...
