Ian Barrett Posted July 23, 2011 Share Posted July 23, 2011 Hey guys, I was drifting the seal into the back of my new swivel last night when I noticed a chip in the teflon coating on the inner edge but outside of the seal. Its not in a place where anything moves, being next to the driveshaft seal. I think it will be fine but I got to thinking what if the teflon comes off or is corroded by the oils inside. Am I worrying unduly? Quote Link to comment Share on other sites More sharing options...
ajh Posted July 23, 2011 Share Posted July 23, 2011 If there's no movement then there's no worry. Quote Link to comment Share on other sites More sharing options...
danebrewer Posted July 29, 2011 Share Posted July 29, 2011 the thing is with those britpart ones, I think they're coated much like the teflon fryin pans, like a skin over the top, so it can peel off, the Genuine LR ones, though they're hineously expensive ( about £300 a pop excluding VAT) are coated by a PVD coating process I thinklike you get on the titanium coated drill bits, much more resillient and it won't peel off, but if nothing's going to be rubbin gon it then I shouldn't worry, the oil shouldn't corrode it at al, after all, the gears, halfshafts and axle tubes all seem to hold up perfectly fine, and they have no coating at all... Quote Link to comment Share on other sites More sharing options...
Ian Barrett Posted July 29, 2011 Author Share Posted July 29, 2011 OK thanks guys. Its all put back together now and its nice to have the peace of mind from your comments. Cheers Quote Link to comment Share on other sites More sharing options...
