Ronny S Posted July 27, 2011 Share Posted July 27, 2011 For a while I have had problems with ABS/TC-light on my MY2006 110 SW. The light started blinking and after a while it's constantly on. Today I found this Anyone know how much I have to change? Or can I just replace the part of the wire that is gone? Partnumber? Ronny S Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2011 Share Posted July 27, 2011 front left sensor is YMD501720 LRSeries or Brit-Car or Craddocks have it listed. Quote Link to comment Share on other sites More sharing options...
Ronny S Posted July 27, 2011 Author Share Posted July 27, 2011 Thanks a lot Western. Do I have to change the whole sensor, or just the wire? Ronny S Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2011 Share Posted July 27, 2011 looks like a new sensor with the wiring connected as far as the next connector, so should be a straight swap. or it might just be the wiring to plug into the sensor & the next connector in the cable run. I cannot find a decent photo of it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 27, 2011 Share Posted July 27, 2011 On the RRC there's a plug along the inside edge of the inner wing, you may find this is the same on the Defender, it's just a small black round two pin plug about 10mm diameter. Quote Link to comment Share on other sites More sharing options...
Ronny S Posted July 27, 2011 Author Share Posted July 27, 2011 Thanks a lot. I'll have a look for the connector/plug tomorrow. Must the new item be adjusted? I think about the teeth in the hub that are giving the signals to the ABS-sensor. And another thing. We put on longer springs, dampers, brakehoses... But is there longer ABS-wiringlooms? I have not lifted my car, but I came to wondering about it. Regards, Ronny S (from Norway) Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2011 Share Posted July 27, 2011 just make sure the sensor it the correct distance from the hub/disc, LR wouldn't have longer cables made for the abs sensors, but a aftermarket supplier might. but don't know of any. Quote Link to comment Share on other sites More sharing options...
