Warthog Posted July 25, 2006 Share Posted July 25, 2006 My exhaust is in need of replacing, the middle and rear box's are coming away from the pipes. Just wondering if it would be o.k or of any benefit to remove them, and make it a straight through? Any comment, or advice? Cheers Quote Link to comment Share on other sites More sharing options...
northernchris Posted July 25, 2006 Share Posted July 25, 2006 My exhaust is in need of replacing, the middle and rear box's are coming away from the pipes. Just wondering if it would be o.k or of any benefit to remove them, and make it a straight through?Any comment, or advice? Cheers Remove the rear box only else it will be pretty noisy,will see abit better performance especially if you tweek the pump. Chris Quote Link to comment Share on other sites More sharing options...
rick Posted July 26, 2006 Share Posted July 26, 2006 My exhaust is in need of replacing, the middle and rear box's are coming away from the pipes. Just wondering if it would be o.k or of any benefit to remove them, and make it a straight through?Any comment, or advice? Cheers both the centre silencer and rear resonator are perforated 'straight through' tubes, so there would be stuff all gain in removing them. Now if you were to upgrade to 3" tube all the way, definately works well, (much quicker spool up, and the effective rev range is vastly extended, at least with a long 130 system) but you need at least a resonator at the rear, the noise is almost unbearable at full boost without anything, and the drone at cruising speed is worse. Quote Link to comment Share on other sites More sharing options...
