Mo Murphy Posted July 28, 2011 Share Posted July 28, 2011 I have a difference of 7mm between the offside and nearside wheelbases. All the bushes and bolts are tight and it doesn't affect the driving of it. Is this within tolerance ? It's not really a problem, it just offended mine eye when I measured out of curiosity Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2011 Share Posted July 28, 2011 no tolerance in the info I've got here, it just says 90 wheelbase -- 2360mm or 92.9 inches. Quote Link to comment Share on other sites More sharing options...
sean f Posted July 28, 2011 Share Posted July 28, 2011 I was told (not sure of the origional source of the info though) when checking a friends 90 that the tolerance is 6mm, since that is 6mm for each axle you could have a 12mm difference and just be in spec. If it drives OK leave it alone, if you really care add spacers behind the bushes or buy x-eng rear arms which are adjustable lenght to square things up. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 28, 2011 Share Posted July 28, 2011 I measured mine (so to speak) the other day and one side was out by ¾” I searched the forum and found a member who said he had known vehicles with 1” difference as standard !. J Quote Link to comment Share on other sites More sharing options...
ToyRoverlander Posted July 29, 2011 Share Posted July 29, 2011 Have someone to push on the other side of the body... bet the difference is gone Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 29, 2011 Share Posted July 29, 2011 Drivers side longer? With the stronger/longer spring in the front drivers side, it could cause the front axle to creep under a little shortening the wheelbase...? That's without a driver of course. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 29, 2011 Share Posted July 29, 2011 Don't panic Mo - its called Tom Jones Syndrome ie - My LR is out by xxmm on one side to the other, is this normal ? Well Sir Mo - Its not unusual" I'll get me coat Right, I can't find the one I have for a 90, but read and cry and weep n laugh at the one I have enclosed, for a RR this shows "Acceptable" tolerances +/- for a chassi - ffs if thats "Acceptable" think how bad the ones "Outside" tolerances are So, in answer do not panick Mr Mo, its all normal (well as normal as can be with a LR ) Mo.pdf Nige Quote Link to comment Share on other sites More sharing options...
cosecon Posted July 29, 2011 Share Posted July 29, 2011 Chassis for Land Rover 90 Hope this helps defender 90 chassis.pdf Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted July 29, 2011 Share Posted July 29, 2011 Well Sir Mo - Its not unusual" I'll get me coat Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 29, 2011 Author Share Posted July 29, 2011 No panic here Nige, I am cool, calm, collected and curious Alliterative too Thanks Toylanderover and Bowie, that sounds quite feasible, what I need to now is measure it whilst I'm driving I think this is probably what it is TBH. Nige & Cosecon, thanks for the diagrams, I find it interesting that in both the RR drawing and the 90 drawing, the spring mount centres fore and aft have no tolerance listed which means either none is allowed OR as I believe, they were too embarassed to put the figures in there Thanks all Mo Quote Link to comment Share on other sites More sharing options...
pat_pending Posted July 29, 2011 Share Posted July 29, 2011 I wouldn't worry about the 7mm, it sounds like the wheelbase is too short by about 17" Mo. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2011 Share Posted July 29, 2011 what I need to now is measure it whilst I'm driving that could be highly dangerous Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 29, 2011 Share Posted July 29, 2011 No panic here Nige, I am cool, calm, collected and curious Alliterative too Thanks Toylanderover and Bowie, that sounds quite feasible, what I need to now is measure it whilst I'm driving I think this is probably what it is TBH. Nige & Cosecon, thanks for the diagrams, I find it interesting that in both the RR drawing and the 90 drawing, the spring mount centres fore and aft have no tolerance listed which means either none is allowed OR as I believe, they were too embarassed to put the figures in there Thanks all Mo How about jacking the chassis up so all 4 wheels were hanging and off the ground? Oh and the body was level .... and the axles. Err... that's probably a stupid idea actually Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 29, 2011 Author Share Posted July 29, 2011 I wouldn't worry about the 7mm, it sounds like the wheelbase is too short by about 17" Mo. You'll not tempt me to the dark side, Mr. Pending Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 29, 2011 Share Posted July 29, 2011 92.9" is definately the correct wheelbase. Quote Link to comment Share on other sites More sharing options...
JeffR Posted July 31, 2011 Share Posted July 31, 2011 That should read 92.9 ish!!!! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 31, 2011 Share Posted July 31, 2011 Where 'ish is number between 16 and 17.1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 31, 2011 Share Posted July 31, 2011 That should read 92.9 ish!!!! 92.9 is the correct wheelbase, whether they actually made a single on with is is another thing XD Quote Link to comment Share on other sites More sharing options...
jbs Posted July 31, 2011 Share Posted July 31, 2011 If you want to be pedantic it's 92.73 inches Quote Link to comment Share on other sites More sharing options...
reads90 Posted July 31, 2011 Share Posted July 31, 2011 If you want to be pedantic it's 92.73 inches But searching for a 90 with that would be like finding the holy Grail Quote Link to comment Share on other sites More sharing options...
jbs Posted July 31, 2011 Share Posted July 31, 2011 But searching for a 90 with that would be like finding the holy Grail Very true but we all know how the tolerances are on Land rovers Quote Link to comment Share on other sites More sharing options...
reads90 Posted July 31, 2011 Share Posted July 31, 2011 Very true but we all know how the tolerances are on Land rovers Yeah the correct tolerance term for Land rovers is "that'll do" in my best brummie accent Quote Link to comment Share on other sites More sharing options...
