Turnip Posted July 29, 2011 Share Posted July 29, 2011 Simple question - if you have a series one to look at! I am putting a new Marslands galv chassis on my 1954 86" and having a little trouble getting my door gaps close enough. The vertical mounts which come up from the outrigger to mount the front of the tub were definatley in front of the front edge of the tub - but it had been removed by the previous owner. My question is - should those two vertical tabs be behind the front ally edge of the tub or in front? Can someone look please? Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted July 29, 2011 Share Posted July 29, 2011 They're behind the alloy on 80 inch and S3 and are on 86 S1. Quote Link to comment Share on other sites More sharing options...
RobotMan Posted July 30, 2011 Share Posted July 30, 2011 Behind and with a bit of rubber shim to keep the Galv and Ali apart. Quote Link to comment Share on other sites More sharing options...
Turnip Posted July 30, 2011 Author Share Posted July 30, 2011 Thanks chaps - that would explain it!! Quote Link to comment Share on other sites More sharing options...
