Ex Member Posted August 13, 2011 Share Posted August 13, 2011 Forget the copper/hide mallet, get alump hammer on it, the steel is VERY hard here, you may mark it, but you won't break it.... If you can find some way of holding the shaft tight all the better, you kind of need to 'shock' the clip out the groove. Actually, I've seen them break. They are very brittle. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted August 16, 2011 Share Posted August 16, 2011 Hmmm... I haven't got a bench, let alone a vice Does the split ring need replacing, or can I re-use it? If you get realy stuck you can use my bench as I am not a million miles away. Let me know if you do and I will clear some space on the bench . Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted August 16, 2011 Share Posted August 16, 2011 If you get realy stuck you can use my bench as I am not a million miles away. Let me know if you do and I will clear some space on the bench . Sorry just read it fully doh you did it...well done Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 16, 2011 Share Posted August 16, 2011 Actually, I've seen them break. They are very brittle. Well they have a bigger one than me then.... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 16, 2011 Author Share Posted August 16, 2011 Sorry just read it fully doh you did it...well done Thank you anyway for the kind offer Quote Link to comment Share on other sites More sharing options...
