Jimmy Two-Jacks Posted August 11, 2011 Share Posted August 11, 2011 Hi All just got a binnacle volt meter/ battery gauge for the 90 and was wondering where to take the live input from? Cheers J Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 11, 2011 Share Posted August 11, 2011 J, Anywhere that is fused and on the switched side of the ignition will be fine Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted August 11, 2011 Share Posted August 11, 2011 Radio is usually quite an easy one to get to, and it also means nothing important dies if for some reason it does blow the fuse Quote Link to comment Share on other sites More sharing options...
tacr2man Posted August 11, 2011 Share Posted August 11, 2011 Must be switched supply or will flatten battery ! Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2011 Share Posted August 11, 2011 any of the plain white wires at ign switch or behind the instrument pack, you should find a few spare white connections as LR used to fit a 'battery condition gauge' to County models. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted August 11, 2011 Author Share Posted August 11, 2011 any of the plain white wires at ign switch or behind the instrument pack, you should find a few spare white connections as LR used to fit a 'battery condition gauge' to County models. Thanks all. J Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted August 13, 2011 Author Share Posted August 13, 2011 Thanks, Now wired in and working well. Quote Link to comment Share on other sites More sharing options...
