"Spare" Inputs?
stuck
Gents,
I note that on Hybrid From Hell's drwaing the MS ECU has several pins marked "Spare"
Are any of these configurable inputs?
I have an in truck PC running a 6" touch screen and was wondering if I could use the ECU & Megatune to display oil pressure (via a transducer obviously)
Cheers,
Mick.
The SPARE pins are just bought out to 4 contacts inside the unit on the PCB, they can be inputs or outputs but you need to connect them to something - the processor has various spare pins (JS_), some of which are analogue so could be used as a pressure sensor input. You'd need to build a signal conditioning circuit to make it work, although that can probably be copied from the existing temperature sensor(s) circuit. You'd also need to know the response curve of the sensor you're using.
Lots of info is in the MegaManual / MSExtra documentation.
