Megatune Temp Gauge
stuck
The .ini files determine the scales of all the gauges for Megatune, you can even define your own gauges (like the fuel consumption gauge).
You need to find the correct .ini file (msns-extra.ini if you're using MS1-Extra code) in your "car" folder. In the [GaugeConfigurations] section there's a definition for the temp gauge that looks like this...
"Coolant Temp",       "%TEMP", -40,   120,    -15,     0,   95,  105, 0, 0
You can edit that line to set the limits and the warning/danger levels (yellow and red areas). The first six numbers allow you to change the low and high values, the low danger level, low warning level, high warning level, high danger level.
Back the file up before you edit it, just in case :)
