stuck Posted August 13, 2011 Share Posted August 13, 2011 Gent's, Just put a 4.6 into my ex Td5, have used a RRC level sender in to the tank but it doesn't seem to work. Is the RRC sender compatible with the Td5 fuel gauge? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted August 13, 2011 Share Posted August 13, 2011 doubt it, normally matched to the gauge. different type of gauges in those 2 vehicle ranges. Quote Link to comment Share on other sites More sharing options...
stuck Posted August 14, 2011 Author Share Posted August 14, 2011 doubt it, normally matched to the gauge. different type of gauges in those 2 vehicle ranges. Thanks Ralph, Any idea what my options are? Ideally I would rather change the gauge than the sender. Ta, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2011 Share Posted August 14, 2011 You might be able to match a VDO fuel gauge to the sender, Td5 gauge IIRC feeds the signal via the speedo head & possibly the ECU. Quote Link to comment Share on other sites More sharing options...
