90MAD Posted August 14, 2011 Share Posted August 14, 2011 hi all due to change of plans and no longer off roading im putting my 90 back to standard height my question is i have cranked front and rear arms can i still use these on standard springs and shocks if not can i use +1" springs and still use my cranked arms Quote Link to comment Share on other sites More sharing options...
martifers Posted August 14, 2011 Share Posted August 14, 2011 No reason why not other than you will have excessive castor - assuming those arms are 3° / 6° corrected. You will have more positive castor so you will have heavier and slightly less responsive steering. If you are not going to put lift (more than 2'') back on in the future you might as well sell your castor corrected and refit standard to make some money if nothing else. For 1'' lift castor correction isn't necessary. Quote Link to comment Share on other sites More sharing options...
90MAD Posted August 14, 2011 Author Share Posted August 14, 2011 cheers for the info i wont be putting a lift back on so will go back to standard what radius and trailing arms will fit my 1989 90 Quote Link to comment Share on other sites More sharing options...
