stuck Posted August 15, 2011 Share Posted August 15, 2011 Gents, When I swapped engines I gave the Td5 loom away with the engine. I've retained the transfer box which has the speed sensor which I now need to wire to the speedo. Drawing only shows one wire going From the sensor to the dash but the sensor has thee pins, any ideas what I need? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 15, 2011 Share Posted August 15, 2011 You'll need an ignition switched live, an earth and the sensor wire to the speedo. HTH Mo Quote Link to comment Share on other sites More sharing options...
stuck Posted August 15, 2011 Author Share Posted August 15, 2011 Cheers Mo. Any idea which pin is which on the sensor? Quote Link to comment Share on other sites More sharing options...
HoSS Posted August 15, 2011 Share Posted August 15, 2011 Cheers Mo. Any idea which pin is which on the sensor? I have this info in my paperwork, as i converted mechanical to TD5 speedo. But i wont be able to check it until friday. IIRC theres more than just 3 wires needed, as theres a perm 12, switched, gnd, sensor and other optional connections. If you are still looking by fri, i will post it. I'm also looking for a TD5 mph speedo urgently if anyone has one. Hoss Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 15, 2011 Share Posted August 15, 2011 Looking into the plug on the harness from l to r, you'll have black/red (sensor), black (earth) and white/green (switched supply). The plug is the same as you'd buy for a NAS tail light, so plenty on ebay etc. HTH Mo Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted August 15, 2011 Share Posted August 15, 2011 You only need three wires at the speed sensor (transducer) end. Everything you need to know is here, and especially in this wiring diagram. Nick. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 15, 2011 Share Posted August 15, 2011 This is what you need: http://www.retroanaconda.com/james/cars/defender/td5_gauges/Gauges%20Wiring%20Diagram.pdf James' wiring diagram Quote Link to comment Share on other sites More sharing options...
stuck Posted August 15, 2011 Author Share Posted August 15, 2011 Thanks very much gents. Superb. Quote Link to comment Share on other sites More sharing options...
murphs Posted May 12, 2020 Share Posted May 12, 2020 Hi i am trying to do this conversion so far new dash fitted all warning lights working I am using a discovery auto box on my defender new sender fitted its a 2 pin sender other posts mention 3 pin no ground when power op warning lights are on speedometer shows millage when i run engine speedo not working tried 2 different speedos where am I going wrong Murphs Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2020 Share Posted May 12, 2020 Discovery unit won't give the correct signal to the speedo, get a defender transducer with the 3 connections it feeds direct to speedo on one pin, earth & 12v feed on the other pins, see the diagram above. 1 Quote Link to comment Share on other sites More sharing options...
rorytheaussie Posted July 6, 2023 Share Posted July 6, 2023 Does any one happen to know the size of the crimp terminal that goes with that plug? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 7, 2023 Share Posted July 7, 2023 8 hours ago, rorytheaussie said: Does any one happen to know the size of the crimp terminal that goes with that plug? Which plug? Quote Link to comment Share on other sites More sharing options...
western Posted July 7, 2023 Share Posted July 7, 2023 @PaulMc he is good with LR electrical connections Quote Link to comment Share on other sites More sharing options...
PaulMc Posted July 7, 2023 Share Posted July 7, 2023 14 hours ago, rorytheaussie said: Does any one happen to know the size of the crimp terminal that goes with that plug? The speedo transducer uses an Econoseal 070 3-way female connector - The terminals are 0.70" (inches), which equates to 1.8mm. 1 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 12, 2023 Share Posted July 12, 2023 Britannica Restorations just made a video for a GPS speedo. Solution? Quote Link to comment Share on other sites More sharing options...
Wytze Posted July 12, 2023 Share Posted July 12, 2023 5 hours ago, Sigi_H said: Britannica Restorations just made a video for a GPS speedo. Solution? In my 109 there is one of those. Work's really well. What ever tyre size or final drive, it's correct, for allmost two year's now. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 12, 2023 Share Posted July 12, 2023 What if you drive in a tunnel? Is signal strength always ok? Quote Link to comment Share on other sites More sharing options...
Wytze Posted July 12, 2023 Share Posted July 12, 2023 7 minutes ago, Sigi_H said: What if you drive in a tunnel? Is signal strength always ok? Long and deep one's , it will fall away i guess, just like navigation system's . Quote Link to comment Share on other sites More sharing options...
TSD Posted July 12, 2023 Share Posted July 12, 2023 GPS driven speedo isn't road legal in the UK (or wasn't, last time I looked). Not that you can't have one of course, just that it doesn't qualify as a speedo. More importantly, that speedo exceeds the total 'nasty plastic chrome' allowance for my entire fleet. 2 1 Quote Link to comment Share on other sites More sharing options...
