Off Road Toad Posted August 24, 2011 Share Posted August 24, 2011 Please can anyone answer the above question, what's it for? I'm about to start converting my 90" (originally a 98my 300tdi) to Td5. I have the complete engine loom and have just bought a new complete 04 spec bulkhead loom and instrument binnacle (inc it's little loom) I thought i had amassed everything i need but now i see there's a fusebox under the seat aswell as the usual bulkhead one? will i need to buy one of these or not? Thanks chaps and chapesses Steve Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 24, 2011 Share Posted August 24, 2011 The power for the car is routed from the battery, through the under seat fusebox, and then into the cabin and the cabin fusebox. Yes you will need it if you want to run a standard Td5 setup, which is arguably the easiest way to go about it! The underseat fusebox is part of the main bulkhead loom, so you should have it, or the connections that fit onto it anyway. It'll be near the ECU connector. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 24, 2011 Share Posted August 24, 2011 It feeds pretty much everything Try and get the original supply cable for it too, one end of which is the battery positive terminal clamp bolt and the other has the correct right angled terminal. HTH Mo Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 24, 2011 Share Posted August 24, 2011 Indeed, a bit like this one, in fact: It runs across the back of the seatbox, from the battery to the underseat fusebox Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted August 25, 2011 Author Share Posted August 25, 2011 Thanks gents, Steve Quote Link to comment Share on other sites More sharing options...
