dorky Posted August 31, 2011 Share Posted August 31, 2011 110 v8, 3.5 on SU,s runs well but only on choke,when warm put choke fully home and just dies. any ideas thanks Quote Link to comment Share on other sites More sharing options...
tacr2man Posted August 31, 2011 Share Posted August 31, 2011 sounds like either an air leak into intake side, so too weak needs choke. Or the mixture screws need adjusting , or throttle butterfly stops needs resetting , as its idling (not) too low. Can you keep it running if you dont use choke (when its at normal running temp)if you keep revs up slightly by using foot? By the way whats your location ? worth putting on your details as people local to you might be able help with your problems ? Quote Link to comment Share on other sites More sharing options...
dorky Posted August 31, 2011 Author Share Posted August 31, 2011 I will have a go with foot on throttle pedal when warm and also check the othe rstuff as well, cheers let you know. thanks also for the heads up on location Quote Link to comment Share on other sites More sharing options...
