Active Anti-Corrosion Control
Any decent engine cleaner and pressure washer should do the trick but remember to protect any water sensitive bits and the effect that some cleaners can have on tarmac etc.
Water sensitive bits? I thought you could drive diesel Landrovers under water (with a snorkel...)? I don't have my own pressure washer so will have to drive to a local garage to ruin their tarmac :)
Yeah you can but rivers don't hit the engine with 1500psi behind them ;)
Senders like oil pressure sender etc, also don't direct it at seals and joints, things like that.
