Speedo not working
snailracer
S3 have a lovely plastic clip which holds the cable into the head - and it breaks - worth having a good look - taking the cable out and seeing if the inner cable is turning properly - or can be twisted when its fully home - ie slipping at the bottom or gearbox end.
If all seems well there - the worm drive gear on the output shaft can slip - take the propshaft of the output flange on the handbrake and check the nut in the centre is done up to 85 lb ft.
