white90 Posted August 2, 2006 Share Posted August 2, 2006 I get this msg: Hello, you either have JavaScript turned off or an old version of Macromedia's Flash Player. Click here to get the latest flash player. when trying to watch the videos "posted on "Your Tube" like the darwin one by Stephen Itt did work for the jeep acrobatics one previously posted any ideas please? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 2, 2006 Share Posted August 2, 2006 I get this msg:Hello, you either have JavaScript turned off or an old version of Macromedia's Flash Player. Click here to get the latest flash player. when trying to watch the videos "posted on "Your Tube" like the darwin one by Stephen Itt did work for the jeep acrobatics one previously posted any ideas please? In short, you need either Java script or a recent version of Flash player to see the films. You should have the option to download one of both at the YouTube website. Essentially, both are a small(ish) program that run on your computer to decode and display the information (in this case a film) on the website. Chris Edit: If you have either program, check that your firewall is allowing it access. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 2, 2006 Share Posted August 2, 2006 I'm guessing you've already tried the really obvious and checked you've got javascript turned on and the latest version of Flash? I'd have though Flash is more likely - lots of other things won't be working if you've turned javascript off. If they both check out okay, YouTube have probably got some dodgy Flash detection script on their site. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 2, 2006 Share Posted August 2, 2006 What browser are you using Tony? As far as I can make out, nothing of any value has ever been done with Javascript that could not be done a better way. (nerd-proof tin hat on) Quote Link to comment Share on other sites More sharing options...
white90 Posted August 2, 2006 Author Share Posted August 2, 2006 IE how would I know if Jave was on or off? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 2, 2006 Share Posted August 2, 2006 In the settings, not sure where it is in IE but there will be an option to enable Java, and probably one to enable JavaScript too. Knowing MS it will be under "Advanced Settings". Quote Link to comment Share on other sites More sharing options...
white90 Posted August 2, 2006 Author Share Posted August 2, 2006 sorted thanks Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 2, 2006 Share Posted August 2, 2006 sorted thanks So what was it? Javascript turned off? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 2, 2006 Author Share Posted August 2, 2006 I loaded the latest version of Flash now it all works cheers again Quote Link to comment Share on other sites More sharing options...
SimonPearson Posted August 2, 2006 Share Posted August 2, 2006 Thought this thread was going to be about coffee.... Quote Link to comment Share on other sites More sharing options...
