redben101 Posted September 18, 2011 Share Posted September 18, 2011 Hi Is this part number STC4858 ( clicky link ) the correct number for the differential flanges ( front + rear) of a 2001 Td5 90? Cheers Ben Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2011 Share Posted September 18, 2011 Yes, also detail here Quote Link to comment Share on other sites More sharing options...
redben101 Posted October 2, 2011 Author Share Posted October 2, 2011 To bring this up again i bought said flanges above, and they are circular instead of rectangular like are currently fitted. When i compared the new flange to the old flange it is approx 12mm deeper. In order to fit the new flanges do i remove the big washer that sits behind the flange, otherwise i am shortening the prop travel by 12mm? Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2011 Share Posted October 2, 2011 the big washer is a mudshield to keep rubbish out of the seal lip. this is the other type http://www.shop4autoparts.net/Defender/Axle/Differential/stc3722-flange-kit-diff-4-bolt-square.html Quote Link to comment Share on other sites More sharing options...
redben101 Posted October 2, 2011 Author Share Posted October 2, 2011 So to clarify i need to return the current circular flanges and get the rectangular ones? Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted October 2, 2011 Share Posted October 2, 2011 NOOOOOO! it's not the mud shield. it's the flange spacer. you have bought the later type flange. Perfectly good for what you want and yes just take out the spacer that sits between the tail bearing and the flange, then it will be exactly the same dimension. All it is, is the spacer is now incorporated into the flange as one piece. Steve Quote Link to comment Share on other sites More sharing options...
redben101 Posted October 2, 2011 Author Share Posted October 2, 2011 Thats great. Thanks Steve Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2011 Share Posted October 2, 2011 didn't realise there was a spacer in the flange kit. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted October 3, 2011 Share Posted October 3, 2011 It's not part of the flange kit normally, its a special item like the pre-load shims. Landrover have realised there's no point making it seperate to the flange now. which makes sense really. Steve Quote Link to comment Share on other sites More sharing options...
