discomikey Posted September 19, 2011 Share Posted September 19, 2011 i need to get these parts... unsure of the name of that, seems to seat the seal between the g/box and xfer/box it is located ont he transfer box side, round the mainshaft output end. convex side towards the rear of the car, concave side towards the gearbox. and these need replacing, they are the springs which go inside the syncromesh for 1st and second, this is the reason my gearbox pops out of second on overrun, as the lip on one end is missing which means it doesent lock in properly. now a new syncro unit is £130. so i dont want to pay that just for 3 springs. also i could do with the brass syncro rings for 3rd and fourth, surely they cant be £130 as there just 2 brass rings, which are far less complex than the syncro for 1st and 2nd. which to be honest am surprised how much the unit costs as its not even that complex itself. Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 19, 2011 Share Posted September 19, 2011 Keith Gotts keep a surprising quantity of series gearbox parts in stock. They've always had everything I've ever wanted for on in stock and on the shelf. Jon Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 19, 2011 Author Share Posted September 19, 2011 cheers ill google them Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 19, 2011 Share Posted September 19, 2011 They dont have an online shop, but are more than happy to mail order you stuff if you phone them up! In fact alot of the main dealers in this area use them for parts! Jon Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 19, 2011 Share Posted September 19, 2011 Get the parts book PDF, find the part numbers, and then either order them from Land Rover or one of the online parts places. LR Series, Brit-car, etc. should all be able to get them. Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 19, 2011 Author Share Posted September 19, 2011 okay cheers, will the pdf cost me? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 19, 2011 Share Posted September 19, 2011 Nope http://www.retroanaconda.com/landrover/2010/03/series-iii-parts-book/ Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 19, 2011 Author Share Posted September 19, 2011 whats the difference between this http://www.brit-car.co.uk/product.php?xProd=80622 and this... http://www.brit-car.co.uk/product.php?xProd=80623 apart from the price? Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 19, 2011 Author Share Posted September 19, 2011 i got it, ones genuine (G) ones pattern (P) Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 19, 2011 Author Share Posted September 19, 2011 bought them along with some other parts, from Brit car, thanks. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted September 20, 2011 Share Posted September 20, 2011 Hang on: The flat spring is RTC 1956 and is from the 3rd/4th synchroniser - at the front of the box. The loose brass rings are the 1st/2nd synchroniser parts. The metal ring (oil thrower) comes off the sleeve. Simply press it off carefully. A common cause of the box slipping out of 1st and 2nd is the nut on the back of the mainshaft working loose - especially if it wasn't tightened properly - especially after fitting overdrive. Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 20, 2011 Author Share Posted September 20, 2011 i got my gears the wrong way round then, still, that spring thing needed replacing, the metal ring thing can do with out replacing. how does this make it pop out of second? it was a bit on the loose side this time but it was properly tight the first time i looked at it, and it popped out of gear then, Quote Link to comment Share on other sites More sharing options...
