Hybrid_From_Hell Posted September 21, 2011 Share Posted September 21, 2011 Looking at the rad cowling, there is a detachable bit that goes and follows the shape of the alternator. I need to have a picture showing how far up / down the alternator the top of the curve of the cowling is level with ? Maybe a pencil lying between the 2 showing the level to the alternator and a piccie ? Any help would be fabbydoos Nige Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 21, 2011 Share Posted September 21, 2011 Serp 3.9 yes? The top removable part is a close fit, bulging out around the pulley. I would say the clearance between the cowl and pulley is only a pencil thickness or so. The rearmost edge is about level with the alternator and of the pulley. Afraid I can't do you any pics as the cowl is not currently fitted to the engine, the above is from memory. Hope this helps Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 21, 2011 Share Posted September 21, 2011 Nige - are you sure you can't save a lot of time and fannying about by just sticking to the electric fan you've already got? Quote Link to comment Share on other sites More sharing options...
AncientGeek Posted September 21, 2011 Share Posted September 21, 2011 I think I know why you want to know.. On my 3.9 Serp I had to trim that cowling with a dremel sort of like the attached to fit the coilpack. I'm away from home right now but can send you a photo over the weekend if wanted Quote Link to comment Share on other sites More sharing options...
task Posted September 21, 2011 Share Posted September 21, 2011 I can take a photo of my 3.9 Serp Disco tomorrow if that'll help? Quote Link to comment Share on other sites More sharing options...
zim Posted September 22, 2011 Share Posted September 22, 2011 Nige, are my pics here any use ? http://forums.lr4x4.com/index.php?showtopic=68879 G Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 22, 2011 Author Share Posted September 22, 2011 Nope You've kindly posted up a 4.6 Serp Cowling fan combo....which I was using but now am not as I don't have a 4.6 rad, and the rad I do have now is better suited to the .9/4.0 engine rather than the sqaurer 4.6 assembly I am having to use a 3.9 cowling and 3.9 Viscous on a 4.0 serp frot end Whilst the 3.9 / 4.0 is basically the same engine same cc etc, the front end is not (Oh HOW I know it F Not ) So I need some pics of both a 3.9 and 4.0 engines to see where the cowling lines up. Any pics from anyone would be goo. Gap from back of top of cowling to alternator and position in terms of height as to where the top of the cowling lines up on how high up the alternator (if that makes sense) Hey ho Nige Quote Link to comment Share on other sites More sharing options...
fozsug Posted September 22, 2011 Share Posted September 22, 2011 Quote Link to comment Share on other sites More sharing options...
task Posted September 22, 2011 Share Posted September 22, 2011 1998 Land Rover Discovery 3.9, if it helps Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 22, 2011 Author Share Posted September 22, 2011 Saw the THOR unit and was worried until I twigged it was a thor !! Anyway pics above are fab, means it helps a lot Thanks all Nige Quote Link to comment Share on other sites More sharing options...
