neonovice Posted September 23, 2011 Share Posted September 23, 2011 Hi, I am having major problems with a 2003 td5 110 defender. It started with a failure to start (if you see what I mean). It turned over but would not fire. After flattening the battery I got her running with a bump start and drove it home without issue. After getting it home when I try to start it I get nothing. Only the oil pressure light comes on on the dash, the starter dosent even click. I have fully charged the battery and still nothing. If the indicator is on when I turn on the ignition I get disco lights on the dash board with the temp gauge going off the scale all the dash lights coming on and alll the exterior lights glowing. I have ordered a new indicator stalk but I doubt this is the issue. Do you think it might be the ECU? If so which one do I get and where from? Is it a straight swap, or is this some jiggery pokery involved? Any / all suggestions / advice appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
crwoody Posted September 23, 2011 Share Posted September 23, 2011 It won't be the indicator switch and isn't very likely to be the ECU, sounds to me like you have a loose earth connection somewhere. I'd start with the one underneath the ECU in the bottom of the seatbox. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted September 23, 2011 Share Posted September 23, 2011 It may be a dodgy starter, they can do funny things on Td5's. Also check relays under seat. Andy Quote Link to comment Share on other sites More sharing options...
neonovice Posted September 23, 2011 Author Share Posted September 23, 2011 Looks like it was a bad earth, just fitting a new stap now. Cheers. Fingers crossed Quote Link to comment Share on other sites More sharing options...
C18RCH Posted September 23, 2011 Share Posted September 23, 2011 Check for oil in the ecu connections both in the engine bay and at the ecu. My TD5 wouldn't start once after a 4 hour drive. Everything came on ok and as normal but when you turned the key nothing, not even trying to turn over. When I checked the starter motor I found it hanging from it's wires! All the bolts had fallen out on the 4 hour drive. Quote Link to comment Share on other sites More sharing options...
neonovice Posted September 23, 2011 Author Share Posted September 23, 2011 Right, As it turns out it was an earth strap (chassis to engine), snapped clean orf! I had a problem with the handbrake being stuck on but as I thought this was unrelated I never mentioned it, but it would appear that as there was no longer an earth, the handbrake cable was earthing between the gearbox and the body and had melted its plastic cover jamming the handbrake on! Anyways, thanks for your help and advice. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 23, 2011 Share Posted September 23, 2011 Rest assured you are not the first one to have encountered the same issue. Glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
buckcherry Posted December 12, 2011 Share Posted December 12, 2011 had the same sort of prob look at yr temp gauge when u try to start it,if it goes to the red then its a condenser under yr seat move it about and it should start Quote Link to comment Share on other sites More sharing options...
buckcherry Posted December 12, 2011 Share Posted December 12, 2011 hi I'm new to this and i sent the wrong advice on my second post its meant to be a relay u have to move.dont no whether u can correct this.thks Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 12, 2011 Share Posted December 12, 2011 hi I'm new to this and i sent the wrong advice on my second post its meant to be a relay u have to move.dont no whether u can correct this.thks Ok I have moved your post for you. Welcome to the forum but please note that it is a text speak free zone Quote Link to comment Share on other sites More sharing options...
