Don Del Posted September 27, 2011 Share Posted September 27, 2011 The felt strips in the rear side windows of my 1999 110 Station Wagon need replacing. I have obtained the spares could anybody give any advice about how best to do the deed? Quote Link to comment Share on other sites More sharing options...
JeffR Posted September 27, 2011 Share Posted September 27, 2011 Fill the gap with silicon..... You need to split the frame to do a proper job, which means removing it from the vehicle. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 27, 2011 Share Posted September 27, 2011 Have a look at this http://forums.lr4x4.com/index.php?showtopic=68899&view=findpost&p=589784 Otherwise you are left with the traditional route of removing the exterior rubber trim, drilling out all the rivets holding the frame in (40 odd per side IIRC), then 4 screws are holding the frame together. Once the frame is split and everything is in bits it's easy enough to put back together.... well sometimes the rubber holding the fixed pane is a bugger to refit actually. Anyway once it's done rivet it all back in and hope the seal to the body doesn't leak Quote Link to comment Share on other sites More sharing options...
Don Del Posted September 27, 2011 Author Share Posted September 27, 2011 Thanks for the feedback. Especially the link to the previous post which is the route I will try. Quote Link to comment Share on other sites More sharing options...
bigbeast Posted September 28, 2011 Share Posted September 28, 2011 i replaced the felt in my sliding windows around 2 years ago with the LR stuff, and they are starting to rattle again, the felt just gets wet and over time and dosent perform as good...i didnt remove my windows, just scrape out the old stuff and work in the new felt using the sliding motion of the window to help push it along, only took around 30-45mins to do both sides..i would recommend that you use the woolies trim as mentioned, i will be using that when i do mine again the near future Quote Link to comment Share on other sites More sharing options...
Joe90's Posted September 18, 2017 Share Posted September 18, 2017 I don't suppose you guys would know how many metres would be needed to replace the window felts on a typical station wagon window? Quote Link to comment Share on other sites More sharing options...
