Relay Wiring Help!
SiWhite
Righto, I've been to the scrapyard and pinched bought an intermittent wiper relay thingy, which I'm hoping to wire into the Landy.
It's the same shape as a standard four terminal relay, but is about 50% as high again.
I think there are five or six terminals on the base, including a 3mm-ish terminal in addition to the 6.3mm terminals.
I've scoured the interweb and cannot find a thing as to how to wire the thing in. Just need to know which terminal is earth, which is permanant 12v, which is switched etc. The terminals are numbered but I don't have that info to hand right now.
Anyone got any info which could be of assistance?
Many thanks as ever!
Cancel Cancel!
A VERY quiet night at work has revealed this list of codes for wiring all sorts of relays - Tech Archive Tony?
1 Low Tension
4 High Tension
15 Ignition controlled feed (Ignition key/switch)
15a Ballast resistor to ignition coil
Glow plug to starter switch
17 start
19 preheat
30 Feed from positive battery terminal, direct
31 earth or battery negative
Electric motors
32 Return
33 Main terminal
45 Starter relay feed to starter input (main current)
Flasher unit
49 Feed
49a Output
50 Starter feed (direct)
Trailer signals
52 Additional signals from trailer to towing vehicle
Wiper motor
53 Feed
53a Wiper (+), self-parking switch
53b Wiper (shunt winding)
53c Windscreen washer pump
53e Wiper (brake winding)
53i Permanent magnet wiper motor third brush (2 speed)
Trailer signals
54 Brake lamps
55 Fog lamps
56 Headlamps
56a Main-beam and main-beam indicator
56b Dip beam
56d Headlamp flash contact
58 Sidelamps,tail lamps,No plate lamps, panel lights
61 Charge warning light
67 Alternator field
72 Beacon lamp switch
75 Radio, cigar lighter
76 loudspeakers
Normally-closed and changeover switches
81 Feed
81a First output
81b Second output
Normally-open switches
82 Feed
82a First output
82b Second output
82z First input
82y Second input
Multi-position switches
83 Feed
83a Output,position 1
83b Output,position 2
83L Output, left hand
83R Output, right hand
Current relays
84 Feed, winding and relay contact
84a Finish of winding
84b Output, relay contact
Switching relays
85 Finish of winding (earth)
86 Start of winding
86a Start of winding or first winding
86b Winding tap or second winding
Normally closed and changeover contacts
87 Input
87a First output (break side)
87b Second output
87c Third output
87z First input
87y Second input
87x Third input
Normally-open and changeover contacts
88 Input
88a First output
88b Second output
88c Third output
88z First input
88y Second input
88x Third input
Generator and generator regulator
B+ Battery positive, generator output
B- Battery negative
D+ Generator positive
D- Generator negative
EX or
EXC Generator field
IND Warning light
Apparently this was published by Bosch. If your car catches fire it's their fault, not mine.
well i would have answered but i did not have anything to add that would have helped you.
I am sat at work too bored with no one to talk to on here. But differance is it is 3pm here and i go home at 5 pm so only 2 hours to go then weekend off :lol:
