Jon W Posted June 11, 2017 Author Share Posted June 11, 2017 Well I have fitted the lowest temperature intermotor stat for the bottom hose, I am trying to sort the bottom rad hose there is less of a kink in it. Also having the extra port from the top by the carbs to the top of the rad fitted. Which apparently speaking to a few people makes a big difference, but can really work out why. Also having a better core put into my rad for better cooling which if calculated correctly will give 25% more capacity. Will let you know how it goes when it's all back together Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 12, 2017 Share Posted June 12, 2017 I'd guess the top bleed hose allows air bubbles to bleed out from the highest spot and keep the system working correctly. Certainly that's true for the EFI manifold. Quote Link to comment Share on other sites More sharing options...
Jon W Posted June 25, 2017 Author Share Posted June 25, 2017 Well I have fitted the rad and lower thermostat, runs at about 85c when moving, then 90-95 when slow or stopped. Need to do some slow lanes to see if it really heats up or see if the fan cools it enough. But so far things are looking a lot better/safer thanks Jon Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 25, 2017 Share Posted June 25, 2017 On 12/06/2017 at 10:33 AM, FridgeFreezer said: I'd guess the top bleed hose allows air bubbles to bleed out from the highest spot and keep the system working correctly. Certainly that's true for the EFI manifold. I'd always wondered about that small hose. Does the manifold have coolant in the side walls? I presume it's to reduce icing when the engine is warm, rather than to cool the induction system? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 26, 2017 Share Posted June 26, 2017 The small hose out of the top of the "lower" inlet manifold (by the temp sender) is supposed to be plumbed to a small heating block under the plenum throttle butterfly, and then out to the top of the rad. 1 Quote Link to comment Share on other sites More sharing options...
