Rear De-mist playing up
Not great on electrics so some help would be great.
My rear demist (1991 200tdi) when switched on comes on after a few seconds or like the last few days a couple of minutes or not at all.
My initial guess would be to take switch apart and clean contacts up then panic as i need to find a relay somewhere.
Anyone point me in the right direction please
rear screen heater switch is just a small rocker type unit, the voltage sensitive relay [VSR] is in the far right corner of the dash [yellow] relay] make sure this is fully seated in it's socket, the heated rear screen relay sits next to the VSR.
have a look/clean the connections at the rear screen as well.
