defender-kris Posted October 18, 2011 Share Posted October 18, 2011 hi lads i have just swoped my engines over as the last one when bang it is a defender 130 300tdi and i put a disco 300tdi engine in it place the engine runs fine when its on tick over the needle on temp gage sit in the midle but as soon as i drive it after 10 min the needle go s on to the red WHY IS THIS any help would be appreciated kris Quote Link to comment Share on other sites More sharing options...
Phillis Posted October 18, 2011 Share Posted October 18, 2011 has it got the defender temperature sender in? or has it still got the discovery as im pretty sure that i read some where that they have different senders? Quote Link to comment Share on other sites More sharing options...
defender-kris Posted October 18, 2011 Author Share Posted October 18, 2011 its got the disco one in it i knew that was the case with 200tdi by not the 300tdi dose any one knew if this is right ?????? Quote Link to comment Share on other sites More sharing options...
Phillis Posted October 19, 2011 Share Posted October 19, 2011 Just had a quick look on google and they are different disco sender - amr1425, defender - amr3321 Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 19, 2011 Share Posted October 19, 2011 could also be a duff thermostat Quote Link to comment Share on other sites More sharing options...
defender-kris Posted October 19, 2011 Author Share Posted October 19, 2011 thanks lads why would it be fine when she is stationary and go on the red when i am driving her Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 19, 2011 Share Posted October 19, 2011 Take the temp sender out of your old Defender engine and put it in the new Discovery engine. Then report back on the gauge readings. Then we can help you to try and diagnose the problem if it still exists. HTH Mo Quote Link to comment Share on other sites More sharing options...
defender-kris Posted October 19, 2011 Author Share Posted October 19, 2011 thanks mate will do Quote Link to comment Share on other sites More sharing options...
defender-kris Posted October 20, 2011 Author Share Posted October 20, 2011 done that but still going up why would this be lads Quote Link to comment Share on other sites More sharing options...
dieselsteve Posted October 20, 2011 Share Posted October 20, 2011 when its showing hot on the gauge run your hand over the rad to see if there are any cold areas Quote Link to comment Share on other sites More sharing options...
Mutley Posted October 20, 2011 Share Posted October 20, 2011 Air lock? just a thought Quote Link to comment Share on other sites More sharing options...
