Mark90 Posted August 7, 2006 Share Posted August 7, 2006 I was swapping the rear diff over today to take the detroit out before 7S so I'm in standard class and thought I'd pull the shafts right out to check them. Just as well i did The diff end of the short shaft... Oh look all twisty... The long shaft had more twist in the splines and less along it's length, long shaft at the top... Only done the J33P club event at 7S and Tony's birthday bash with these shafts and the locker. I think I must have done the damage at 7S as I don't recall pushing that hard at Tony's, however i did at 7S Luckily I had a spare set of shafts, which are now fitted. Unluckily I only had one spare set so has anyone got any 10 spline thick flange drum braked rear 90 shafts, either standard or uprated (yeh i know, but thought I'd ask anyway ) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 7, 2006 Share Posted August 7, 2006 You rough blighter Very close I would say! What make were the shafts, just out of interest? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 7, 2006 Share Posted August 7, 2006 Cadbury. Chris Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 7, 2006 Share Posted August 7, 2006 Cadbury. Chris Good - glad to see everybody is still boycotting Nestle Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 7, 2006 Share Posted August 7, 2006 KITKAT Shafts Have a break, have a KITKAT Ok Ok I'm Going Nige Quote Link to comment Share on other sites More sharing options...
minivin Posted August 7, 2006 Share Posted August 7, 2006 He need's a Yorkie shaft, as his present one's aint "man" enough Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 7, 2006 Share Posted August 7, 2006 oh yeah do you remember that slope that tim went up it's not as if you were giving it any wellie up there now was it! Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 7, 2006 Author Share Posted August 7, 2006 Aye Jim that's where I'm reckoning it was done. Shafts are bog standard and of unknown vintage/milage, as are the one that have just gone in, sans locker though. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 7, 2006 Share Posted August 7, 2006 Aye Jim that's where I'm reckoning it was done.Shafts are bog standard and of unknown vintage/milage, as are the one that have just gone in, sans locker though. Ahhh, you need Lindt ones then. Chris Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 7, 2006 Share Posted August 7, 2006 Luckily I had a spare set of shafts, which are now fitted. Unluckily I only had one spare set so has anyone got any 10 spline thick flange drum braked rear 90 shafts, either standard or uprated (yeh i know, but thought I'd ask anyway ) Don't suppose the ones out of an '86 disc braked rangie are the same are they? Cause I have a pair of them sat in the garage, and they're bugger all use to me. Quote Link to comment Share on other sites More sharing options...
ripley Posted August 7, 2006 Share Posted August 7, 2006 I was swapping the rear diff over today to take the detroit out before 7S so I'm in standard class and thought I'd pull the shafts right out to check them. Just as well i did The diff end of the short shaft... Oh look all twisty... The long shaft had more twist in the splines and less along it's length, long shaft at the top... Only done the J33P club event at 7S and Tony's birthday bash with these shafts and the locker. I think I must have done the damage at 7S as I don't recall pushing that hard at Tony's, however i did at 7S Luckily I had a spare set of shafts, which are now fitted. Unluckily I only had one spare set so has anyone got any 10 spline thick flange drum braked rear 90 shafts, either standard or uprated (yeh i know, but thought I'd ask anyway ) im sure ive got some in the shed, i'll have a look Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 7, 2006 Author Share Posted August 7, 2006 I guess those will be the mushroom head ones with imperial (9/16" spanner) bolts, in which case they won't fit, thanks anyway. Oh and that other package arrived today. Looks just the job. Many thanks, I owe you one Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 7, 2006 Share Posted August 7, 2006 I guess those will be the mushroom head ones with imperial (9/16" spanner) bolts, in which case they won't fit, thanks anyway. 'Fraid so. Anyone else got a use for them? Free to a good home. Oh and that other package arrived today. Looks just the job. Many thanks, I owe you one No problem - glad it was the right bracket. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 7, 2006 Author Share Posted August 7, 2006 Just to clarify this is what the shafts look like... The short shaft is 27.5" and the long one is 38" Thanks Quote Link to comment Share on other sites More sharing options...
ripley Posted August 7, 2006 Share Posted August 7, 2006 Just to clarify this is what the shafts look like... The short shaft is 27.5" and the long one is 38" Thanks mark ive got 2 sets in my shed 1 set even has the drive flanges, if you want them tere yours foc Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 7, 2006 Author Share Posted August 7, 2006 Thanks Graham Only problem is getting them I might be picking some up at the weekend when I'm at 7S, if that doesn't come off I shall see about getting yours. Although seeing how long these lasted maybe I can't have enough Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 7, 2006 Share Posted August 7, 2006 Looks like you are spoiled for them now Mark ! That was a close call ! Mo Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 8, 2006 Share Posted August 8, 2006 It's a shame our diffs arn't centrally mounted in the axle, otherwise you could swap the shafts over and twist them "back" into shape.... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 8, 2006 Share Posted August 8, 2006 Mark, Don't panic. I have spares. (I think coz I can't see the pics at work) Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 8, 2006 Author Share Posted August 8, 2006 If you do bring them at the w/e. Hopefully we won't need them with not having the locker fitted. Quote Link to comment Share on other sites More sharing options...
JST Posted August 8, 2006 Share Posted August 8, 2006 that was lucky Mark, its you V8 boys too much right foot? try some ashcrofts shafts..... Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 8, 2006 Share Posted August 8, 2006 that was lucky Mark, its you V8 boys too much right foot? must be nice to be able to givge it too much right foot though surely? not that i'm saying yours is underpowered or anything! Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 8, 2006 Author Share Posted August 8, 2006 that was lucky Mark, its you V8 boys too much right foot?try some ashcrofts shafts..... Aye too much right foot, but like Jim says there is a point to us V8 boys using the right foot, we get power and lovely noise and we get up the hill without winching Sod the fuel and half shafts. Ashcrofts, no it's a 10 spline diff, besides I'm not fitting any uprated bits till I've rebuilt a disc braked axle to swap for this drum braked one. Quote Link to comment Share on other sites More sharing options...
jules Posted August 9, 2006 Share Posted August 9, 2006 I was swapping the rear diff over today to take the detroit out before 7S so I'm in standard class and thought I'd pull the shafts right out to check them. Just as well i did The diff end of the short shaft... Oh look all twisty... The long shaft had more twist in the splines and less along it's length, long shaft at the top... Only done the J33P club event at 7S and Tony's birthday bash with these shafts and the locker. I think I must have done the damage at 7S as I don't recall pushing that hard at Tony's, however i did at 7S Luckily I had a spare set of shafts, which are now fitted. Unluckily I only had one spare set so has anyone got any 10 spline thick flange drum braked rear 90 shafts, either standard or uprated (yeh i know, but thought I'd ask anyway ) I have two just like that Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 9, 2006 Share Posted August 9, 2006 I have two just like that ...and one that went a little further Quote Link to comment Share on other sites More sharing options...
